outerbanks
Have one engine that is running very rough. (Not running on all cylinders)
Has a hard time starting. Will only idle for about 1 min. Idles rough. If I run the engine in nutral at about 1200 rpms it will stay online, but again very rough. I took it out and the engine will only reach about 3500 rpms in gear. Replaced all the plugs and noticed that the plugs on the port side of the motor were not firing. pulled the injectors and tested them as well with a meter and all seems fine. Pressure tested Air and Fuel rail all is perfect. Pulled the tracker valve again all is fine. Checked the shift / throttle control along with position censor and again all is fine.
I pulled one of the plugs left it connected and grounded it to a external (off motor) ground and it was firing. Once back in the engine... it was not firing.
Ran through all of the coils with meter and resistance matches whats stated on the manual.
I am at a stand still... the engine is not throwing any codes.
Anyone deal with anything like this?
Thanks,
Steve
Thanks,
Steve
