Took on water over the weekend, belts/pulleys sprayed water all over engine (did see alternator hit 16volts). Engine died, cannot restart.
1. Spark on all 8 cylinders,
2. Fuel pressure ~40psig
3. NOID light on all injector plugs shows injectors getting signal.
4. Timing light shows #1 ignition at correct time on pulley.
Will not fire at all, even tried starting fluid.
