I own a 1987 Sea Ray 28'-0
I own a 1987 Sea Ray 28'-0" Sundancer with twin small block Mercruiser V-8 gasoline engines. The starboard engine will run perfectly anywhere between 3000 to 3500 rpm for 15 to 60 minutes and then will start to drop power. If I let it continue with out pulling the throttle back it will die. If I reduce the throttle back to 2000 or lower and let it run for a few minutes and then advance the throttle it will run prefectly and then repeat the same problem. If I shut the engine down and let it sit for 10 to 15 minutes I can run at 3500 for 10 to 15 minites and then the problem will repeat itself. If I take the engine out of gear and let the engine run at 2500 to 3000 rpm it does not lose power. I have recently changed the fuel filter and had a tune up but this has not corrected the problem. Any ideas this is driving me crazy? I have had it looked at by several mechanics but it won't repeat the problem in the shop. Help!!!!!
