HI all,
I have a mercruiser 260 with 350 chevy enigine. Recently overhauled(last week) because of bearing problems. Now the motor won`t run propperly. If put under torque it dont plain at all, when outside with muflers on it only goes up to 4000 rpm. Did not had this problem in the past. Could it be that the valve timing is not 100% correct? Will the motor start if the valve timing is not 100% correct? It seems to backfire alot around 4500rpm and if it is getting too much fuel.
