Merc model 110 9.8HP
Rake12
Merc model 110 9.8HP no points, I believe I am correct with the(110 model) have one of these and need some help serial # is 4243430 I believe it might be a 1975(please correct me if wrong) My problem was no spark, but now I have spark to one plug only,any ideas. Here is what I have done. Disconnected the ground off the kill switch, when I change the coils from one side to the other I then get spark on that coil so this tells me both coils are working. I am thinking switch box but am not sure how to test it.I did try my volt meter on the box and pull it over I get about 52 volts. Tried the other two for the other coil and only 0 to 7 volts so I assume the switch box is bad. But I do not know how to actually test it,any help would be appreciated. PS when I put the serial # into the search it says nothing found.:)
Thanks guys
