"870,
It is a hazy, drizzly
"870,
It is a hazy, drizzly day here in the west end of Long Island Sound, which is perfect weather for browsing through Mercury parts manuals.
The remote control that you have was made in a few different configurations, but they are essentially the same.
The number that I came up with for the actual Mercury part is 29566 which updates to 30162, and lists for around $30. It has five contacts which use screws for attatching the wires.
They also made this same box without the separate choke switch that you have, and simply plugged the hole for the switch.
You could use a typical outboard ignition switch with the push type choke feature. You don't have to use the "c" terminal for the choke wire, or you could choose to use it and eliminate the choke switch on top of the box. This would come in handy if the choke switch broke.
All you would have to do is attatch the grey wire to the "c" terminal of the ignition switch instead of to the choke switch. You would also have to attatch the white wire which provides 12 volts to the choke switch and tachometer plug to the accessory terminal on the ignition switch. Eliminate the white pigtail which now leads to the choke switch.
If you want to leave the choke as is, simply attatch the white wire to the accessory terminal on the ignition switch. This is the terminal that has twelve volts when you turn the key to the on position. It may be labeled "I" or "A". Don't attatch anything to the "C" terminal.
