R
Robert Gomez
Guest
"Hello folks,
Great site w
"Hello folks,
Great site with a wealth of info. I'm having issues with my engine and I wanted to post these questions to see if you can lead me in the right direction to get it resolved. I have a 1996 Marada 21 ft bowrider with a Chevy 5.0 liter, 2 barrel carb and a Apha I (Gen II) outdrive.
Within the last six months, I have replaced the following: spark plugs, spark plug wires, distributor, rotor and the coil. All new parts are Quicksilver marine parts for this engine.
My problems started out (prior to my replacing the parts mentioned above) with the engine cutting out on me and I determined that the coil had gone bad (because of heat). I put a new one on and have approximately 12-15 hours on it and this last weekend, the engine cut out on me again. Last time, I let it cool off and then it would satrt but this time it was dead. Luckily, I was close to shore (West Coast of Florida) and was able to get to shore and get a new one (non marine Accel coil for a Chevy 305). I installed it and the engine turned on on the very next try. QUESTION: Is there anything other than heat that can kill a coil? Mine is mounted right behind the head and seems to start acting up only when we pull the tube (Obrien). We also pull my son skiing and both sons on kneeboards and never had a problem.
The other issue I am currently having is that I took it out the next day and once I got it in the water, I turned it on and let it idle while I finished getting my gear into the boat. About 2 minutes after, it shut down and I have not been able to get it started again. It turns over and sounds like it wants to start but it just doesn't. I suspect its a fuel issue and would like to know if there is anything that I need to look for that can help me resolve this.
Thanks in advance,
RObert"
Great site w
"Hello folks,
Thanks in advance,
RObert"
