I'm in the process of adding plumbing to my Live well and it has no drain. At the moment it only has an overflow and what I'm guessing is the inlet/aerator tube (Both will be removed). My problem is, I've never done this before and have no idea what to use for the drain. I want to put it thru the bottom of the well. Can I use a thru hull fitting and a plug and just cut off what I don't need at the bottom of the boat? I have in mind everything else that will be added but this drain is my stopping point.
