P
poboy
Guest
"just finished engine and hull
"just finished engine and hull survey as well as sea trial on an '84 Silverton 34 Convertible. Lots of little issues, but only one major mechanical hitch - the starboard heat exchanger has both internal and external leaks. Seawater has entered the closed circuit fresh water system and the tank is leaking (spraying). Have no idea how long the fresh water system has been compromised, but the engine ran out fine, compression on the low side, but within specs (110 to 120). Obviously the exchanger must be replaced, but am wondering how concerned I should be over the block and manifold cooling passages being exposed to saltwater. Any thoughts would be appreciated!
Paul"
Paul"
