northern_lights
"Just wondering if these temps
"Just wondering if these temps sound within range for other 454's. At 30 mins at 2000rpm, (This is in Northern CA so water temp is mid-50's) Header manifold 181-deg, Riser Elbow 88-deg, Heat Exchanger top tank 165-deg, bottom tank 137-deg, Water pump (top of engine) 151-deg, Manifold top (behind carb) 129-deg. Note: 1986 Crusaders w/700 hrs new hosing, heat exch,& water pumps. Both engines are within 3-5 degrees of each other. Gauge on dash reads 130-degrees."
