curt_garrett
"Well, I got my upper gear set
"Well, I got my upper gear set replaced and had clutch Dog done at same time. Now clutch dog slips badly, tryed to adjust it so it engaged further but to get it to work I have to adjust it so far that the cutout switch trys to engage. I was told by a local mechanic it is probably a bent Bell Crank. He says it is common when you have a clutch dog slipping as the old one did to bend the bell crank, but you can't tell its bent until you actually remove and inspect it. Any thoughts on this. It is very depressing to have all this work done, then it slips worse than it did previously. I tryed opening engine hatch and pulling shift linkage forward about 1/8" and it stopped slipping as I finished moving boat from launch ramp to my berth. I was also told that they make a bell crank upgrade kit for about $150.00 and it only requires drilling out a small tab and installing it. That is if the bell crank is actually bent and needs replacement. Can anyone think of anything else that would cause clutch dog to slip, besides the bell crank or a bad adjustment. I had lower end inspected while upper gear set was being replaced and the mechanic said the only thing he saw wrong with lower end was chips on the clutch dog which he replaced. Please help if you have suggestions to cure this problem.
Bummed in Calif."
Bummed in Calif."
