Johnson rds 40hp 1968
hi my out board hasnt been r
hi my out board hasnt been run for around 5 yrs it has compression and spark. i have cleaned the carby several times . the motor fire's now and again the plugs arnt oiling up or wet i seem to have a problem getting fuel from the carby to the cylinders .any sudjestion would be great
"clogged,sticking reed valves
"clogged,sticking reed valves is a possibility--
they r behind the carb,in the intake."
yep i agree but i have had
yep i agree but i have had this motor going for short oeriods ..seconds rather than minuts... checking water pump etc ...replaced water pump .. got motor going again .. now fails to start ... could the temp warning light have something to do with problem .it is stuck on red ..
"no,..disc the sender wire on
"no,..disc the sender wire on hd,and see if light goes off...make sure spark will jump a 1/4 gap.blue spark....inst ne plugs---champion,j6c,gap at .030...re-ck carb...make sure no water in fuel...use fresh fuel."
been there done all that ...
been there done all that ...i am sure this is a lack of fuel problem ..have tried spraying fuel into carb.. nothing..have even tried the engine start ..nothing .. fuel is just not getting to cylinders..will try looking at reed valves when daylight finaly gets here
"reed valves r really trbl fre
"reed valves r really trbl free,but prob can occur,usually broken rv's....but sitting that long,could be a clog of some sort.."
"ok how big should the hole
"ok how big should the hole for the tube that comes from the cut out switch be?.currently i have a pin hole size hole there , it looks like it has been cast that way."
"that is part of linkage,and s
"that is part of linkage,and synchronization adjustments..on your eng,..it is extremely simple...there should be a line,on throttle cam,..it should pick up,the throttle rlr,at this point....but,this is'nt keeping u fr starting."
Did it run 5 years ago when it
Did it run 5 years ago when it was put into storage? You should do a compression test before you go any further...Is the fuel new and what ratio is it mixed at? Crankshaft seals??? It's hard to intelligently guess until the compression test is done
"very true......fuel mix,..or
"very true......fuel mix,..or lack ,tho,wont keep it fr starting...crankshaft seals are a running prob,..not a st prob.."
ok yes it was running when
ok yes it was running when put into storage ..it has been running for a short time since seconds rather than minutes when i tested the water pump..installed new water pump .. had the motor going again to test water pump ..it was sucessfull . now wont start at all but does fire now and again i have stripped the carby down yet again and rebuilt it ...some parts for this carby are unavailable in nz ..compression seems to be good lumpy motor ..compression tester i used was faulty .. no oil around points etc from uper crank seal .. the motor looks like new very tidy but i do realise looks arnt everything .. new fuel in tanks fuel is mixed as owners manual states 50-1 motor has never been used in salt water..and has had very little use for its age
"ok....pull the flywheel,..cle
"ok....pull the flywheel,..clean points w/alcohol,..blow dry,set gap at .020,..and i would prefer new points,....make sure old points are not burnt..they need to look good.if u can,inst a compl tune kit...still,alcohol cln new points.u may have decent fire,at the wrong time."
ok heres progress i think th
ok heres progress i think the crank seal have failed thats all i can think of now .local johnson dealer say at least $1500 to fix but says some parts will be unavailable ...so they realy want me to buy a new motor ...will get somebody else to look at it
ok update spark jumps at l
ok update spark jumps at least 1/4 inch closer to 1/2 inch compression in both cylinders with motor cold and dry cylinders 100psi on both cylinders havent taken off by pass covers as yet ..is there anything that could leak behind them
