Replaced the water pump/impeller kit and cannot get lower foot to pump water. I have ordered 3 different kits and none work. I have e done this before several times before in other motors without any problems. I have tried it in a bucket of water with a drill motor on the shaft and also attached to the engine and out in the lake. Still no water pumping out. Yes the pee hose is cleaned out. I first thought the brass sleeve inside the rubber impeller might have broke loose. That’s why I have bought 2 additional impellers and I still get same result. The little key pin that goes in the impeller is definitely in place. Any suggestions?
