Johnson 35 hp help
ernie1
I have a 2000 35 hp 3 cyl two weeks ago I ran the motor all day it ran perfect like it normally does then sunday I launched I couldent pull the rope I checked the neutral lock its good then pulled the lower unit and still cant pull it it didn't run hot the day I ran it any help would be helpful
thanks
Can you reach under the flywheel cover to turn the flywheel.-----Remove spark plugs and see if it pulls over.----Hopefully the oil injection has been removed and thrown away !
Thanks for the reply
ya I removed all the injection crap and I pulled off the pull rope , tried to turn it by hand and it moves a little but I didn't have the right size socket to use a braker bar I sprayed some penetrating oil in the cylinders and try again tomorrow
Before you put a breaker bar on it pull the lower unit off and see if it turns over. The lower unit can do the same thing if you have a bad bearing or broken gear.
?????--------The poster said he removed the lower unit in post # 1-----------And what happened when you removed the sparkplugs ????
