Yeah, it's an issue. Something is very unhappy. But it is probably not a belt itself, since they don't make noises. It is something driven by a belt, either the power steering pump or the alternator. You can figure out which by removing the power steering belt (the first one that is removable) and seeing if the noise stays or goes away. Or use a stethoscope.Please see link here for video with audio.
I'm very new to boats, and my MerCruiser inboard is making a squealing noise when in neutral or in low RPM.
Sounds like the belt to me, any guides on replacing this myself if that's the case?
Right, could also be the water pump which is driven by a belt. Forgot about that one. Should not take very long to figure out which, and get it repaired.Its most likely the alternator or circulating water pump. Remove the belts and turn by hand, look for play and feel for roughness
Think you found the issueI've removed the alt belt and it's no longer making the noise.
