thelasthour
"350 300hp carbed with ballast
"350 300hp carbed with ballast resistor. My problem started last month and has now gotten worse. Last month I could only start the boat cold if I temporarily "bridged the posts" in the ballast resistor. Jeff concluded that the starter solenoid may be having a problem. Yesterday I did my normal "bridge" and it blew the fuse on the ignition. I replaced the fuse and tried it once more and blew the fuse again. I removed my "bridge" and replaced the fuse with no more fuse blowing, but still no start. The engine would consistently start for 1 second. I assume it is not getting power to the coil in the "run" position and only in the "start" position. My second observation is that the buzzer alarm was not "sounding" in the normal key position of "run". It would begin sounding in the key position of "start". When i moved the wires under the key switch in the "run" position i would get sporatic buzzer alarm. Does this mean the key switch itself is causing all of this? I did not have a volt meter with me, so I could not diagnose further. I'm thinking the key switch has failed in the "run" position. Any other theories would be appreciated.
STeve"
STeve"
