Hi all,
I have a no start situation with my port engine. It cranks but will not fire at all. There is fuel in the carb bowl (accelerator pump squirts fuel), so I assume there is no spark.
I have the Crusader shop manual and will check the ignition coil and pickup coil resistance values. I will swap in another igntion control module if the other 2 parts are good.
Will an OEM AC Delco module or equivalent work or do I need a marine-specific part? Same question about the igniton coil, do I need the marine specific part? Is there really any difference between standard GM parts and the Crusader/Sierra versions? Does anyone have the part numbers for these?
Thanks,
Barry
Thanks,
Barry
