2002 Mercury 60hp 4stroke motor with 209-218psi on all 4 cyl, spark is good, all good as checked, cleaned carburators 3 times, all passages flow good, acceleration plungers are good and front nozzles spray strong, new needle valves and all floats are good and levelled..
New rectifier, new fuel pump, changed out coils...
Motor will starts right up and idles nice, put in gears vibrated a bit, but can troll around all day. As soon as I gradually increased speed, motor virated harder and stalled. Starts right up. If I slammed on throttle to WOT, it took off quickly on plane and ran like a champ. Gradually decreased speed, it would vibrate and stall out (shut off immediately). But if I quickly dropped it down to neutral, it would stay running. So somewhere in the 2000-3000rpm this vibration gets huge and stalls the engine. Other than that it runs ok. I am really stump right now and don't know what to do next. Could it be a stator issue? I pulled the head and check valves and all are good. New head gasket is on the way. Valves open and shut in order 1,3,4,2...no problem. I readjusted some of the valves before reinstall them. But at this moment, I can't afford to go dig around further without having a good direction to go...
Any advice is deeply appreciated.
