J
Jim Gagnon
Guest
"I have a Honda 45hp. Over the
"I have a Honda 45hp. Over the winter I pulled the carbs off broke them down, soaked them in carb cleaner, put in all new gaskets, o-rings and pilot screws.
I just recently put them back on the motor and with the initial setting as specified by the factory shop manual I fired it up. I made the applicable idle setting, synchronized them and proceded to set the pilot screws.
The initial setting per the manual stated to lightly seat them then turn out 2 1/8 turns. The adjustment procedure says to turn the screw in or out in 1/8 increments utill you get to the highest idle. I attached a separate dwell tach because I figured it was more sensitive than the dash tach for this type of adjustments.
It didn't seem to make much difference at all turning the pilot screws in or out and I was going at least a full turn or more in either direction. At one point during my adjustments I decided to reseat the particular pilot screw I was adjusting and bring it back to the initial 2 1/8 out setting. Just as I was getting down "prior" to where it was going to seat I noticed the engine idle started to climb conciderably. I kind of ignored this and proceded to lightly seat the scew and back it out again to the initial 2 1/8 out setting.
Thinking about it now is it possible that these screws need to be adjusted that far in to where I actually noticed the idle was increasing or should I just leave them alone? I guess I didn't expected to have to make that much of an adjustment but the more I think about my small engine experience I guess that is what I would do on my lawn equipment. I'm not sure if I should worry about that or not but don't want to mess up anything.
I just don't want to take a chance if I'm not positive and I thought that maybe someone out there with more experience than me might be able to guide me a little.
Any help is appreciated .
Jim"
Jim"
