I have a 1999 Honda 9.9 that has run over 150 hrs flawlessly as a trolling motor since purchased. Recenltly I took it off one boat and transported it 10 hrs into Canada to be used on a 14 ft boat. Yes, it was transported w/correct side up. The motor would start and run when the choke is pulled on then off then on then off repeatedly. It will also run full throttle but not idle or run when throttled back to less than 1/2 throttle. It would stall out. I noticed a small amount of fuel on the surface of the water but can't figure out where its coming from (possibly exhaust). What has gone wrong with the carb. Is this a stuck float?
Thanks for the help.
