Hi. My 1994 crusader 454xl high temp light is on and steam is coming from exhaust only a few minutes after starting the engine. I have run it and the temp never gets over 160F, but the high temp light stays on.
Last year I did have an overheating problem and resolved that with the replacement of my raw water pump. ( I also got u-tube cleaned, cleaned out the heat exchanger, replaced the thermostat and replaced the fresh water pump, replaced the exhaust elbows too.) Everything was fine and there was no steam in the exhaust.
Since the light came on this season, I have checked the strainer and also pulled a couple of spark plugs to check if there was any indication of water. Both looked good. I am also going to check the impeller even though that was brand new mid season last year.
Any ideas what might be the cause?
