High performance nose cone and prop info
madmitch66
"Does anyone know where to loo
"Does anyone know where to look for over the hub exhaust, surfacing propellers, that will fit my V6 suzuki? I found Bob's Nose Cones. A good source for Low water pickup nose cones. But there is no info that I can find on surfacing props for suzuki outboards. Mercury Marine makes a prop they call the Chopper II. But they don't have any suzuki listing. Will a mercury prop work on a Suzuki? My '88 150 super six pushes my 20' Sea Craft cuddy 55.1 MPH on the GPS. I want more!! I figure the nose cone, trick prop, and raise it up 4 to 6 inches, she should go 60 or more. Any help would be greatly appriciated."
dont bother with a surface pie
dont bother with a surface piercing chopper prop
unless you install a hydraulic jack plate
you can take a mercury chopper and have it reworked for your zuki
if you do install a jack plate you must have a low water pickup
a chopper is designed to run half way out of the water if you dont have a low water pick up you will smoke your motor
because your pick up on a factory gear case is on the side when you jack up your motor to get the prop where it needs to be your pickups will be out of the water
when you choose speed its a everything or nothing deal
yamaha and mercs are interchangable zukis are not
there is no advantage to a chopper unless it is half way out of the water
