Help with corrosion removal
ccm
Hello,
I have a 2006 Yamaha F150 that has developed some corrosion on the lower unit. I discovered it when I removed the prop to lubricate the splines. It is kind of hard for me to describe where the corrosion is but it is inside of the space where the thrust washer sits. Due to its location it will be really hard to remove via sanding or with a file. My questions are:
What would you recommend to use to remove the corrosion?
Should I prime and paint over the areas after I remove the corrosion?
I have some Yamaha paint that I could use to repaint the cleaned
surfaces. Do I need to use a special primer?
Thanks in advance for your suggestions.
Charlie
