Help Identifying Motor Year and Model
johntdsb
Hello All. The tag has worn out on my motor and I have no idea of what year and model it is. The serial number is G2971187. Is there anyone here that can find out what model and year it is by the serial number?
Hi John, welcome. Does it have a cap on the powerhead somewhere that looks like this?
Got a picture or two? You have to reduce picture size to below 1k. Perhaps it's a replacement powerhead?
This is the best I can do with pictures for now. The boat is winterized and stored. The cowling looks like part of it was painted in the past (the burgandy part)
the boat itself is a 1991 but im not sure if its the original motor. I want to know the model number so that I can order parts for it
currently a water pump kit and Lower Unit Drain Plugs. There might be more but I havent looked into what else I should do to the motor. ? I bought it last summer and it ran great. The previous owner said it was serviced in the spring and good to go. Im not really sure what was done or what I should do out of precaution.
water pump impeller should be easy to find.--Drain plugs are the same from 1950 to 2007 I think.--Your local boat shop ( if you have one ) should be glad to help.
