" I've got an opportunity
" I've got an opportunity to buy two 1989 Crusader 454s to replace my older ones. They are in great cosmetic shape and the owner says he was fanatic about regular pro maintenance. The motors are on pallets, so I pulled the plugs, opened the throttle valve, hooked up the starter battery I pulled from my boat with some OK jumper cables, and took compression measurements with screw-in gauge (but could only get fitting finger tight - no room for wrench). The motors were last run about 6-8 weeks ago.
Compression ranged from 108 to 131, most around 110-120. The thing is, the motors turned SLOW. Maybe 1 second or more between surges. One motor was slower than the other. I know the battery and jumpers are a big question mark. After this I took the same battery and jumpers, and did the same with one of my motors, plugs still in. It turned over at least 2X as fast.
Any suggestions how to interpret this? Is that OK compression under the circumstances? Would a leak down test be a better test, and is it possible for an amateur to do one?
I'd also be interested if y'all think the $3000 per motor price (complete w/transmission) is fair.
Many thanks,
Mike "
Many thanks,
Mike "
