I realize that this isn't a crusader problem but always impressed with the smarts on this forum. I've got a Kohler 6.5 kW genset that starts up and runs for a 15 or 20 seconds and then the carburetor floods and it stalls. It's almost as if the float valve is stuck open. Interestingly enough I have a second unit that I removed the Carb from and exchanged with the first unit and get the same result. If I pull the connector off of the fuel pump the genset will run for a couple of minutes until it runs out of gas in the Carb.
Any thoughts from the engine experts?
Thanks for your assistance.
Tom.
Tom.
