I have a mariener 60 hp 2 stroke. It runs wide open then kinda stalls. I let idle slow for a little . Then can run again. If I run half throttle may run with no problems. I believe if runs out of gas and fulls back up again. I replaced the fuel filter on the motor and also replaced the external big fuel filter comming from the tank. I bought the boat and sat outside for a yr as moved acrossed the USA. I put 10 gal fresh gas in the boat . I’m trying to run all gas out now. My next guess is to rebuild the carb. I have another question. How to tilt motor manually. It wouldn’t tilt and found the wire became disconnected. I see a big screw beside the lift shock that has s pic of oil squirting out. Is that the bleeder you losen and lift the motor. Thanks for any help.
