I'm helping a friend trouble shoot a fuel delivery problem on his starboard Gen IV Crusader 454 with mechanical fuel pumps.* His Port motor has no issues and is connected to the same fuel tank as the starboard motor thats getting no gas.* We swapped fuel lines at the fuel tank pickup (there's one for each motor) thinking maybe the anit-siphon valve was misbehaving or perhaps the pickup was clogged, but the*Port motor runs fine on the starboard pickup and the starboard motor still doesn't run with the carb completely dry.* If we pour fuel*in*the starboard carb it will fire right up.
We disconnected the fuel line at the starboard carb and cranked the engine--no fuel.* We were able to blow fuel back from the connection at the tank to the input of*the starboard fuel pump so the lines are not clogged.* Also*both the*bulkhead mounted fuel*filters and the engine mounted canister filters are brand new.
We bought another pump even though the mechanical ones rarely fail.* This was installed while I was away but it doesn't pump either, and the one we took out seems perfectly fine.* One of our dockmates is pretty sure the push rod to the pump that was replaced is bent, which could very well be the problem.* The other possibility is a wiped cam lobe*at the pump push rod.* If that's the case maybe an electric pump is in our future...
Any advice on further trobule shooting, push rod replacement, or installing an electric pump would be most appreciated.
Best wishes,
Tom
Best wishes,
Tom
