Fuel pump change and now Oil Alarm
25SeaFox04
Hello All,
I recently installed a new fuel pump in the vst tank. I replaced everything back and started the engine. The oil alarm goes off after a few seconds and restricts the rpms. I am curious what could I have disconnected or damaged on the intake side of the engine to cause this? I did struggle to get the manifold back in place but managed after a bit to install, thinking I could have crimped or damaged a sensor, is there anything on that side that would cause an alarm. The motor ran great with no alarms prior to the repair.
Also notice when you just turn the switch to on that motor has 10 qik beeps before even starting the engine, while the other engine does not have those 10 or so qik beeps.
