dhindelang
I have a F150TLR 2006 Yamaha 4 stroke. It starts and runs fine for 5 mins under load. Then it fuel starves and spits and sputters. I have changed all hoses and filters except VST. It has two tanks and switching one to the other does not change anything. Also after it stumbles I can pull it back to idle for about a minute and it will catch up and run fine again for 3-5 mins. Checked the two low pressure pumps this morning and all seems perfect. No tears in any diaphragms or gaskets. After reassembling and running symptoms are exactly the same. I'm fixing to remove the vst tank and check that. Would a hanging float valve in the vst tank cause it to loose fuel and overheat? I changed the vst filter year before last. What is the most perplexing is why it runs ok and fails at exactly the same time. Any suggestions? Thanks. Doug
