mark_searay
Hello, I have an 85 Sea Ray SRV255 twin 470’s and fuel gauge or sender is acting up.
On first use this year gauge initially bounced from 90% full, the actual level to empty and eventually stayed full "empty". Now on second trip gauge deflects to full travel “empty” when ignition is on or boat is running. When the pink (sender) wire is jumped to ground at the gauge the gauge deflects to full. With the key “on” it is hard over to empty, now all the time, thus jumping the purple to ground doesn’t do anything. All grounds are tight, gauge connections clean. Cleaned the sender connections but the ground rivet holding the sender spade lug spins. When ignition is off, gauge releases back to about "1/8th tank".
I’m 3 hours from boat and didn’t measure resistance of sender, should have. Tank is metal, 150 gal., I believe the sender and know the gauge is original. Any thoughts as to if the sender or gauge is bad? Access to the sender is terrible.
Thanks, Mark
Thanks, Mark
