Evinrude identifacion
R
Robert Alderman
Guest
"I recently purchased a boat a
"I recently purchased a boat and by the title it says motor is a 65 hp evinrude, the model # is no longer visable and the serial # is J0001505 can you tell me what i have year and model or direct me to where I might find it. Not having any luck look at all these other web sights."
"Your serial number is actuall
"Your serial number is actually for a Johnson, but other than that, it doesn't give much information at all.
The model number contains all the "useful" information. It should be located on transom bracket near the exhaust housing (leg) or thereabouts.
Depending on the year of the motor, the serial number (for sure) and maybe the model number will also be on a welsh plug (silver disc about the size of a quarter) located on the water jacket of the cylinders.
I will include a pic of what, and approximately where you are looking..
I thought the serial # looked
I thought the serial # looked like a johnson but the engine cover says evinrude and all the stickers on the engine say evinrude. The only welch plug I can find is on top of the engione just under the flywheel in the back if your looking from the front back. Motor runs fine but wanted to due a tune up and replace the water pump thats why I wanted to know the year if possible.The part# I've have gotten off the engine cross reference anywhere from a 71 to and 89
"There always is the possibili
"There always is the possibility that someone swapped something out at some point - Evinrude serial numbers (in this vintage) start with an 'e', the 'j' is a dead giveaway that it's a Johnson.
Where is this serial number located???"
"Serial # is on the identifica
"Serial # is on the identification plate on the transom mount, you can't read the model # anymore its wore off or been scratched, off only welch plug I can find doesn't have any numbers on it. I tryed to send a pic of the engine but file is to big and won't take it."
