Hello, I have a 2001 5.7L GS. The engine wont stay running unless I hold the key in the start position all the time.
I have 12 volts at the ignition switch on the red battery wire. I have 12 volts on the purple ignition wire when the key is in the run position. I have zero volts on the yellow solenoid wire when the key is in the run position.
I have read that a bad oil pressure switch may cause this, but I am unsure how to test that. I do have good oil pressure when the engine is running.
Any thoughts?
Any thoughts?
