Andrew davis
I have a 2001 johnson 30 hp 2 stroke it runs fine in the low rpms but as soon as you rev it past 2500 rpm it starts thumping and wont rev. I pulled the fuel filter of and there was alot of gunk in it i cleaned it out it was one of the screen types.when i first start it runs fine for a minute or 2 then it starts thumping and wont rev.when i tilted the gas tank up to the side where the intake is. it ran fine for about 45 minutes. however that stop working is it bad gas or somthing else i cleaned the tank with some water still no affect the spark plugs look fine. What should i do. is the bowl of the carb gunked up.
