I have a 1988 Carver 38, with twin 7.4 gas engines. The Starboard side has developed a "Ticking" sound. At idle(and all rpm's), the motor has a tick on the top side of the engine. At the same time, I'm showing higher than normal temp and higher than normal oil pressure(80 psi). When I say normal, I'm comparing the starboard engine to the port engine running at the same time. I have a video of the motor running. Just did an oil change hoping that may give some insight. Not sure where to start. Thanks for any thoughts.
7.4 running
7.4 running
