knuckle47
Advanced Contributor
"Almost to the point of comple
"Almost to the point of completing this 4 month engine project. I had to replace the stuffing box tube as my shafts were rubbing against the old stainless tubes and worn a hole in one of them. Therefore, to eliminate this messy backbraking job, I am changing BOTH to bronze (twice as thick) and replacing the not ready to be changed cutlass bearings.
Since my V-drives are directly mounted to the block, I need to raise the level of the shaft in the tube about 3/8" to center the shaft. DOES anyone know if LOWERING the front motor mounts are the same as raising the rear? OR am I thinking incorrectly (again) !"
