bulletine
Just a follow up, some may remember that I was tackling the tach and sync gauge issue of not being accurate. Friday I finally got around to disconnecting the engine harness plugs at the rear of the engine. Cleaned the corrosion off and sprayed with electronic cleaner, but ran out so I used dielectric grease and put both of them back to together (1 for each engine)
The results are great, now my tach sits on 0 when key is off and they both appear accurate and now the sync gauge seems to be working great. A month or so ago, I did clean all the connections behind the dash panel and also on the coil and distributors.
Next is the tune up.
