I had my 1985(?) Mercruiser MCM 230 5.0L engine rebuilt due to freeze damage. I (finally) got the boat back the day before leaving for vacation. I launched the boat and had a very difficult time to get it to start, and it would die when shifting from reverse to forward. When I did get it to finally start, I took it out for a run and kept it at or below 3000 RPM. On the third lap around the lake, the engine slowed, stopped and then would not turn over. I seemed to be VERY hot, even though the water temperature gauge never went above 160 degrees F.
After a ruined vacation, I returned the boat to the place that did the work on my way home. The newly rebuilt engine had overheated and seized. The engine is equipped with a 4 barrel Rochester carburetor (P/N 1347-8296). The repair facility told me that the carb's accelerator pump was sticky and diluted the oil with fuel, causing the engine to overheat and seize.
Does anyone have any experience with, or believe that the engine's catastrophic failure (with no indication of overheating) was due to a sticky accelerator pump? Is this a reasonable cause of the failure?
When I started the engine in the spring it fired up just fine, as it always had, and idled normally (without roughness). I found the freeze damage when the temperature gauge wasn't coming up after a couple of minutes of starting. That's when I found it leaking water (I was running it with muffs for cooling). I don't believe the engine had a chance to get very hot, since I shut it down immediately when I saw the leaks. There was no indication of water getting into and mixing with the oil. The carb seemed to be performing just fine at that time.
