Dt55 clutch rod disconnect for lower unit removal suzuki 1994 dt 55 hp
mikeinva
"Hello,
I am preparing to replace the impeller on my '94 DT55. What is the proper way to disconnect the clutch rod to avoid lower unit problems? There is not much detail for this step in my Seloc manual.
Thanks very much,
mike"
Re: Dt55 clutch rod disconnect for lower unit removal suzuki
OK I figured it in case anyone searches. there is a rubber tab on the starboard side that you pop off. use 12mm socket to loosen the nut almost off and then push the assembly in. you can see the connection under the carbs from the port side.
