DT 75
P
Paul Williams
Guest
"I have just purchased a DT 75
"I have just purchased a DT 75, it starts and runs fine, however when traveling fowards there is an intermittent clunk coming from the engine area. It does not seem to be a miss fire but more like the engine slamming against the transom.This clunk is quite large and can be felt through the boat.I have noticed ware in the gear linkage mechanism in the engine, could it be a momentry drop out of gear? there is no crunching or grating, its just like some one hitting the transom with a hammer."
You need to check shift cablem
You need to check shift cablem adjustment ----likely the clutch is jumping out of forward and if left will cost you a bundle.It may be too late already and a teardown of the propshaft bits is required.
"I have taken the the final ac
"I have taken the the final actuating arm out of the engine, its the arm which pushes the gear rod down to the box.The holes in the casing which hold this arm look to be made to suit a 10mm diameter arm, when the arm in the engine is only 8mm in diameter,so obviously this is causing a lot of play. I am not sure when looking at it that the arm is a suzuki part. could this be anything to do with the problem."
There is a bushing that fits i
There is a bushing that fits in there that either fell out when you pulled the clutch rod out or was already missing. Go to Brown's Point Marina online and look at parts break down to see what you are dealing with.
