"Hi. Thank you for your reply.
"Hi. Thank you for your reply.Sorry I have been slow checking my Emails half way through moving house, major job & pain in the butt. The problem I am having was interment with the ignition switch ( I think ) some times it would be fine other times I would have to turn the key three or four times before anything happened. the same with the kill switch and the trim & tilt. Sent the boat in for a service recently and everything was fine. Now nothing at all is working from the controls. Trim and Tilt works fine at the motor and the battery is good. I want to back track and check all the wiring first. Failing that how do I check the switches etc. ?????? I have only found one fuse so far and it is good. All help greatly appreciated. Thank You. Michael. B."
