John M. Daniel
I removed the lower unit to install a water pump kit. When I pulled the lower unit, there is no seal ring or wear sleeve on the shaft or stuck in the splines in the crank shaft. The parts list shows these each located on the shaft for this model.
The drive shaft does not have the seal ring "Notch" in the upper part of the shaft that my Force 90HP had.
Does this model have these parts?
Also there was gear lube from the lower unit on the top side of the gear case around the shift shaft area. I have not removed the shift shaft retainer yet.
Can the O ring and seal be replace easily once the retainer is removed?
Thanks everyone!
Thanks everyone!
