Dist Cap Corrosion
"Went through some PM on my 45
"Went through some PM on my 454 crusaders today and found that my starboard engine cap had all brass contact legs inside distributor cap corroded badly (green color) even the centrifical advance area and other steel areas showing signs of rusting. The Port dist is fine and still looks new, slight burning at edges of contact posts inside the dist. ?? History: The distributor(s) are petronix flame thrower billet electronic, marine and 60,000 volt coils with 6 MM wires NGK plugs etc! (all matching components) and were installed less that 80 hrs ago. What could be causing this ??"
"Moisture. Look for any way w
"Moisture. Look for any way water may be getting on the distributor. Air intakes, leaky deck drains, and exhaust leak, etc."
"Strange how only one side doe
"Strange how only one side does that, but we've all seen it before. Check to see if the vent in the distributor is open and not getting water splashed on it.
Jeff"
