DF25 Suzuki Lower unit disassembly question
dataphat
"The top plate on the lower un
"The top plate on the lower unit has to be removed because the driveshaft seal is leaking pressue thus water in the gearcase..
I have removed the 2 alignment pins, 2 hex bolts,and 4 waterpump studs.
Placing 3 extended length screws in the threaded holes provided and running them down, the top plate keeps wanting to pull down(due to the spring I suppose).
So I guess it is necessary to go inside and remove the pinion nut to get the top plate off??"
"It was there...<[img]"http://
"It was there...
FIG.12
http://www.outboardparts.com.au/suzuki/PDF/DF25_30(00-06).pdf"
