DF15 Idle Mystery
S
solstice
Guest
"Need your help with an idle i
"Need your help with an idle issue on a brand new four stroke 15 hp. The dealer is slammed this week so I'm trying to figure it out myself so I can get on the water. Here's my problem in neutral the engine idles down to the right rpm. But when I shift in forward or reverse and throttle up then down to idle, the idle rpm is 2-300 rpm higher than in neutral. Makes it kind of hard to shift to neutral. If I wait about 15 seconds the engine eventually idles down to the proper rpm when in gear. When I take the cowling off and watch throttle valve return to the idle position, it looks like it returns to the same place both in gear and out. If I can get the engine out of gear and into neutral then I give it some gas and then throttle back and it comes back to the right rpm. the gas in the tank is about a month old and does not appear to have any water in the tank. Any ideas?"
