I got the strut reinstalled yesterday and checked a couple of things. I measured the area where the bearing wears on the shaft and then did the same in a few other spots on the shaft. The measurements were essentially the same.
I don't have any play (maybe "play" is too strong a word) side to side but measure 0.010 moving up and down. I have an 1.25" shaft. In looking at the chart the Mark posted, it shows 1" and then jumps to 1.5". What's interesting is the "Minimum operating clearances" are 0.015 and 0.016 respectively.
If I'm reading that chart correctly, I'm actually below that range so if anything, the clearance is a little tight. I'm less worried about that, the shaft spins easily dry. I should be ok. Do you guys agree?
Bob
Bob
