You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an
alternative browser.
Cummins spare parts clearance
Hi All
We are clearing out all our Cummins Marine Spare Parts!
ALL parts are a fraction of their current retail price!
Send me a message or email on
[email protected] for your requirements.
Regards
PARTS
Hi All
SEE BELOW:
| Part No | Description |
| 178558 | DRIVE BELT |
| 179901 | VALVE SHUT OFF |
| 3012470 | SCREW |
| 3028521 | DRIVE BELT |
| 3286503 | FUEL/WATER SEPERATOR |
| 3288812 | DRIVE BELT |
| 3288856 | DRIVE BELT |
| 3289056 | DRIVE BELT |
| 3318318 | COOLANT FILTER |
| 3318853 | OIL FILTER |
| 3349230 | ENGINE MOUNTS |
| 3408529 | SENSOR |
| 3408570 | SENSOR |
| 3802335 | INJECTOR |
| 3824517 | SPRAY PAINT |
| 3866478 | SPRING AIR FILTER RETAINING |
| 3903112 | SCREW |
| 3903380 | WASHER INJECTOR RETURN |
| 3903475 | RING SAL |
| 3910343 | GASKET HEAT EXCHANGER |
| 3910556 | WASHER |
| 3911586 | BELT V RIBBED |
| 3920692 | RING RTG |
| 3921926 | GASKET TURBO |
| 3921961 | GASKET TURBO EXH |
| 3930906 | GASKET COVER |
| 3937226 | PLUG |
| 3939258 | GASKET LIFT FUEL PUMP |
| 3944961 | BRT CRC |
| 3970463 | ANODE |
| 3971758 | WIRING HARNESS |
| 3971759 | RESISTOR |
| 3972071 | THERMOSTAT |
| 3974456 | IMPELLER |
| 3975127 | DRIVE BELT |
| 3975770 | TEE |
| 4025337 | INJECTOR |
| 4058964 | COOLANT FILTER |
| 00100000A | ADAPTOR MALE ELBOW |
| 10478998RECON | STARTER MOTOR |
| 3802335RX | INJECTOR RECON |
| 3935530RX | ALTERNATOR |
| CC2602M | COOLANT TEST KIT |
| DV15102 | SENDER PRESSURE VDO GAUGE |
| FF105D | FUEL FILTER |
| FS1009 | FUEL/WATER SEPERATOR |
| HC9083 | PLUMBING KIT |
| HF6522 | HYDRAULIC FILTER |
| LF3349 | OIL FILTER |
| LF9001 | OIL FILTER |
| S962E | DRAIN COCK |
| TM4293001 | OIL PRESSURE WARNING SWITCH |
PARTS
Regards
PARTS
Hi All
SEE BELOW:
| 3012470 | SCREW |
| 3408529 | SENSOR |
| 3408570 | SENSOR |
| 3903112 | SCREW |
| 3910556 | WASHER |
| 3937226 | PLUG |
| 3944961 | BRT CRC |
| 3970463 | ANODE |
| 3975770 | TEE |
Regards
PARTS
