I have a pair of Crusader 7.4MPI closed cooling V-drive engines in a 2001 Gibson 44'. Both engines are original and have 100 hours of freshwater use. On cold starts, both engines fire right up as they should. The problem I am having is that the starboard engine does not want to start right back up after running it for 15 minutes to an hour like it did when it was cold. This only occurs when the engine is still warm and trying to start it after sitting for an hour or two. The port engine fires right up on warm starts, but the starboard is very difficult to start. It turns over and over just fine, but will not start easily or at all. Frustrated with this yesterday and not wanting to come in on one engine, I used starting fluid several times and it would fire up with the fluid sprayed in, but die again after it burned through. Finally, on my last attempt, I was able to keep it running after the starting fluid burned through and it ran fine and normal for 20 minutes back in to the marina. After getting in the slip and shutting down, I tried starting it 30 minutes later and same problem of not starting. This morning after sitting all night and cold, it fired right up as normal. The problem has been occurring for several months now. I have fresh fuel in the tanks, changed the fuel water seperator filters, cleaned flame arrestor, new plugs & wires and rotor. Any thoughts would be appreciated.
