correct gaskets
bumhead
OK,any one know the correct gaskets for gen iv 454 merc Fwc.I need the gasket between the riser and the manifold.4 slot 2slot or blocked?They are GLM center riser.
The gaskets should be an exact match with the number of slots in the riser & manifold. If full fresh water cooled, meaning the manifolds have antifreeze in them. You must use a blanking plate with a gasket between the riser & the plate & between the plate & the manifold.
