I have been working for several monthsto determine the cause of a weak port engine. (2002 350 CaptainsChoice, a MEFI-4 injected engine). Above about 2500 rpm the throttlemust steadily be advanced more than the starboard to keep up. Atabout 3500 rpm or so it is maxed out and the starboard is at about athird. Since we don't run long distances (mostly local trolling andwhale watching) I have only worked on it when I had a chance. Boatstill fishes great and at 1800 rpm you would never know there was aproblem.
Fuel issues have been addressed(filters, etc.) finally culminating in a pressure test that showedthe correct 58 psi at WOT. So fuel starvation is not the problem. Ascan showed all sensors in range and Cam Retard correct. I alsochecked throttle opening carefully and switched the manifold airpressure sensor with the other engine.
Today I finally got around to acompression test (the port side of the motor is near the poop tankand water heater and a ***** to get at, so it is not easy). Anyway,all cylinders tested 180-190 psi except for #5 which was at 15.
So I know the problem but have aquestion. No way can I get the head off of that side of the enginewhile it is in the boat. I think I can (with some considerable effort) removeenough stuff to get the valve cover off. As interesting as thatwould be, in most cases I expect I would still have to have themarina pull the engine and then remove the head. Or would I? I am trying tothink of some reasonably likely case where I could fix the problemwithout head removal. Since the pressure difference is so drastic(and oil consumption is zero) I don't think it is rings. It must bea valve issue. The engine makes no strange noises or tapping. I canthink of two situations. First, I could have a valve not closing allthe way or severely burned. If the valve is dropped and bent orrusted wide open or burned then I need to pull the motor and take off the head. But if it is a broken spring (this seems unlikely) that is causingthe valve to stay open, then I can fix from above.
Second, I am also (hopefully) thinking one mightget a very low compression reading if the intake valve had failedshut. The exhaust valve stays open until near the top of its cyclemeaning there would be very little to compress if the intake neveropened. Could that give me the 15psi reading? (When that cylinderis tested instead of the whir sound, followed by a compression sound,followed by a whir [you do it four times to get an accurate reading]I just hear a constant whir, with no huffing or puffing). A nonopening intake could be caused by a broken push rod or a rocker armstud that backed out over time. Neither of those require headremoval, unless the push rod failed because of a frozen valve. Or it could be a cam lobe failure meaning the engine mustbe pulled.
We have a handful of experts on thisboard and I would very much like some feedback. If there is a highlikelihood I need to pull the motor in any case I will do so andavoid spending a day or so wedged over the engine trying to get thevalve cover off. But if you guys have seen this issue solved fromabove on occasion, it might be worth doing. What I do not want to dois pull the engine and then find a simple problem that could havebeen handled in the boat.
Thanks for your help.
CaboJohn
CaboJohn
